4 members (Peggy M, Gray_Ghost, Wally / Montana, 2-Ton), 106 guests, and 2 robots.
Topics128,052
Posts1,055,717
I've got a 52 Chevy truck, with a rebuilt 216 engine. It starts fine when cold, but when warm, it won't start, nor fire. Any ideas what's going on would be appreciated. Bob
Are you saying it does not crank over when warm, or it cranks with out starting?
My Blog
It cranks without starting.
One last question. Is it 6 or been converted to 12 volts?
My Blog
Nope, is still a 6 volt.
Hey Tim, thanks for the response. Tomorrow I'm off to buy new cables. Bob
If your coil is marginal, the lower voltage when cranking can make the difference between starting and not starting. Here is a way to check for this problem. Disconnect the power feed to the coil and hook it up to a battery charger. If it starts quickly under those circumstances then you know what the problem is.
Also, on some the carburetor percolates a little. The technique for that condition is to gently put the gas to the floor, leave it there for about a minute and then without moving it, try starting it again. This requires both feet!
1951 1 Ton Completed
Thanks for the reply. I've put a new coil on the truck. Iwill give the starting technique you mentioned a try. Bob
I remember in shop class a long time ago, the teacher said the points need to come off the negative side of the coil. If not you can have the same problem your talking about. Wont start when warm. Dont know?
