| | | Forums66 Topics128,151 Posts1,056,994 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 24 New Guy | | New Guy Joined: Aug 2011 Posts: 24 | On a related topic to Pump Gas in a 216.(oddly enough I am related to the author. Oddly, in this context, is to be taken in the broadest possible terms). Sorry, brother dear.
I am old enough to remember Regular and Ethel at the pumps - and the associated rude humor. Ethel, as I recall, being short for tetra ethel lead. My brother's question was about a '38 truck. When did manufacturers begin designing engines for leaded fuel? Or when did it come into general use? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | TEL came into use in the early 20’s as an inexpensive way of booting the octane rating which paved the way for higher compression ratios for internal combustion engines used in aircraft and automobiles. Here is a line excerpted from wiki: “Founded in 1923Ethyl Corp was formed by General Motors and Standard Oil of New Jersey (ESSO). General Motors had the "use patent" for TEL as an antiknock, based on the work of Thomas Midgley, Jr., and ESSO had the patent for the manufacture of TEL.”
Prior to the introduction of TEL many of the early engines ran on white gas. When I was a kid in the 40’s, small stationary engines still ran on white gas which had a very low octane rating somewhere in the neighborhood of 50-60 and it was carried by most gas stations. Today Colman gas and Naphtha are very similar to what was called white gas. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 |
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | And don't forget, we lived in a LOW LEAD world from late 60's to early 70's, when we finally got the lead out! (apologies to Led Zeppelin.)
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
