| | | Forums66 Topics128,110 Posts1,056,274 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | I forgot to ask, do I need to do anything to run pump gas in my 'bolt?
Tom | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Do you mean 87 octane E10 fuel???
Just pump it in and drive it.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I'm not sure why you would be asking such a question. I am pretty sure there is more to this question than what was asked. But you have to put it in the tank. If you leave it in the gas station you won't get very far. | | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | Maybe a shop manual to figure out where your gas tank is first? :-) Idk. Must be early. I just cannot understand the question.  | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | He may be asking if it's safe to run unleaded. The answer to that is yes, it's safe.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tom,
Do not let the folks scare you off from asking questions. However, a little information about your concerns would get you better answers.
Are you worried about dirty gas tank or dirty fuel lines or dried out carburetor?
Are you worried about octane or non-leaded gas or ethonal in the gas?
Denny's response is most likely all you need to know.
| | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | You guys aren't using lead additive? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Nope. Dump it in from the pump, and put the peddle to the metal. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You guys aren't using lead additive? If I ever am lucky enough to find a 1964 Ford Custom with the 390 Thunderbird Police Interceptor package (like the one my Mom had when her 4 boys learned how to drive), I would be looking for a lead additive, I think. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | these engines don't really produce enough combustion chamber heat to really hurt much. They only have 5.5-1 or 6.5-1 compression. (depending on which year you have) which is one of the reasons you only get 15-17 MPG out of one. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | No kidding? Guess I can start using the money from lead additive savings for more parts!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Even the 8.25 compression ratio 235 would most likely not be harmed by lead free gas, unless in an a continuous high revving situation.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | 12K now on the valve job and never put anything in the '50, 216 but Marathon 87 octane e10. Never could get it to ping no matter how far I advanced it and out of curiosity I've advanced it till the starter wouldn't turn it over. DG
| | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Oops! I guess that was pretty vague just asking about the gas! I was heading toward not having lead in the gas anymore, did I need differant valves, hardened seats, etc. Thanks for pointing the error of my ways!
Tom | | |
