Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 30 guests, and 4 robots.
Topics128,003
Posts1,055,244
Members48,418
Is .010 - intake and .020 - exhaust a typical starting point for valve adjustment when you are rebuilding your rocker arm assembly?
Then, I assume that once you get the motor warmed up, you readjust the valves closer to .008 & .015 ?
Craig
Sounds good to me.
My Blog
I was told to set new valve adjustment (cold) at 0.05 over the hot adjustment on solid lifter engines. Then readjust after warm up.
I just did this. I decided to do a cold adjustment at three thousandths wider than spec. So mine was .009 for intakes and .019 for exhaust. I ran it yesterday and it clacks a bit but will be doing a hot adjustment today. Even with the wider gaps, it's quieter now that I'm actually getting oil to the rockers. That wasn't the case earlier and they were really noisy.
1956 Chevy 3200
Roberr54,
My guess is that you mean .005, as described in the valve-adjustment section in the Shop Manual?
Sounds like my beast which also wasn't getting any oil to it's rocker arm assembly. Today I'll finish installing and do the cold adjust.
Craig
Yes you are right. My mistake
