1 members (klhansen),
160
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#8272 01/27/2002 11:02 PM | Joined: Jul 2001 Posts: 19 Junior Member | | Junior Member Joined: Jul 2001 Posts: 19 | I bought a 3/4 ton eaton rear end out of a 72 chevy that I am going to swap third members with a 50 1 ton to get 4.10 gears. The 72 axle has wider brakes than the 50 does. Is it possible to swap rear hubs on these axles? I would also have to swap backing plates and the entire brake assembly. The outer bearing # is B11630 and the inner bearing # is O11784 on the 72 axle. I have not torn into the 50 axle yet but I have an interchange manual that says the outer bearing # should be B11630 and the inner # should be D11786. The outer bearing # matches. Or, should I just weld spring mounts on the 72 axle and use the entire axle? Thanks | | |
#8273 01/28/2002 12:01 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I believe the difference in numbers is the difference in bearings BEING the early ones have barrel type(shape) roller bearings and the newer ones have tapered rollers.
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you haven't done so yet, measure the housing length. You should find the newer housing is 3.5 inches longer. I have thought about the swap, but haven't been able to justify the expense of narrowing the housing.
Fred 52 3600 69 C-10
#8275 01/28/2002 12:23 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | My 68 C-20 has barrel shaped roller bearings in the full floating rear hubs. I just measured a rear axle cut from a 50 Chevy 3/4 ton panel. The full floater axle measured 63 inches between the two wheel mounting flanges.Seems a little wide? | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Axle splines the same?????
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by Mechainiac: Axle splines the same????? If they're both Eaton, yes. There are some Dana rears out there. You should be able to swap the pumpkin if you want to keep the original width. It would be worthwhile to see if the brake & hub assembly will swap out. Take em apart and see what happens.
| | | | | Joined: Jul 2001 Posts: 19 Junior Member | | Junior Member Joined: Jul 2001 Posts: 19 | Thanks guys, Later in the spring (when and if the snow melts) I will try the hub swap. If the hub works, I might be able to use the original axles. I'll post my results. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Make sure you guys are checking the measurement on the axle shafts left-to-left,and right-to-right One side is 31&1/2 inches.One is 37&1/2 inches.
