2 members (BC59, Gray_Ghost),
154
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,079 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 21 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 21 | My '50 3/4 ton has a '59 235 L6 in place. The radiator has a top fitting of 1 1/4 dia and the thermostat housing neck on the 235 has a 1 1/2 dia. Did the earlier 216's and 235's have a 1 1/4 themostat housing neck? How are people handling this difference of size. I am trying to find a reducer sleeve to handle this. Anyone else have any experience on this and part #'s or solutions? Any help is appreciated.
Thanks.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Use a housing off a 216, then all will match.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2011 Posts: 21 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 21 | Use a housing off a 216, then all will match. The footprint the same? Any laying around? | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | water necks for 216s are all over ebay... | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | They are usually dirt cheap too.
