| | | Forums66 Topics128,156 Posts1,057,018 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | My seal which seems to be made of rubber has always leaked oil. I have noticed that I've always been able to slide the ball housing with collar attached and tightened back and forth on the torque tube pretty easily.
The U joint gasket kit that I recently got has a cork seal. Is this a better material for this particular application? I did install it and it was a bear to stuff this seal into the collar with the two steel compression washers. Now sliding just the collar up and down the torque tube requires some major effort.
Should I dress this cork seal with something?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Sorry, I might have mislead you. I meant to say that when I have the ball housing disconnected from the back of the tranny and slide it back along the torque tube to access the UJoint, it has been very easy to slide back when I have the ball housing attached and tightened down.
Now that I have installed the new cork seal in the collar and it attached to the ball housing, it is very tough to slide it forward so I can attach the ball housing to the back of the tranny. Just wondering if I should maybe apply some Hylomar or something similar to the inside and outside diamater of the cork seal.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | is this the seal your refering to? ...pic... ...pic... or this one? ...pic... | | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 |
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I just replaced mine and it was a very tight seal, so it took some force to slide it up to the yoke in order to thread the cap on. I didn't add any lubricant to it.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I just dressed up the area where the seal sits on the torque tube. Knocked any burrs down with some fine emery and cleaned the rest with scotch pad. ...pic... I don’t recall having any problem sliding it in place. By the way my leak at the ball collar stopped but the torque tube still has a slight leak. Good Luck | | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Oh well, we all do when we get to a certain age - LOL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I just dressed up the area where the seal sits on the torque tube. Knocked any burrs down with some fine emery and cleaned the rest with scotch pad. ...pic... I don’t recall having any problem sliding it in place. By the way my leak at the ball collar stopped but the torque tube still has a slight leak. Good Luck I think I would have put that o-ring seal between the two washers. Where does the torque tube still have a leak? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The seal is between the 2 steel washers in that pic The seal that came in the kit is more like a quad ring. Before putting the new seals in I was leaving a pretty good witness mark everywhere I parked. Now it just a small drip. Is there an O-ring available? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | DADS50,
Sorry. I had looked at the photo on an old LCD monitor at work - bad contrast distortion.
Some people have reported using an o-ring seal. I prefer one like yours.
I have never had a torque-tube that did not leak (drip a liittle) behind that seal.
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | But which is better cork or that rubber seal ?
| | | | | Joined: Jun 2011 Posts: 63 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 63 | Sorry to hijack this thread: Tim, with a small drip like the one at the torque tube (DAD'S50's picture) how can we tell how much fluid has been lost, say, after two or three weeks, short of having to drain out the fluid and refilling the tranny? Thanks. | | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Pull the fill plug and insert finger?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Pull the fill plug and insert finger?  And, remember, if it stops leaking, you are too low on fluid.  | | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 |
