2 members (delky, Steelonsteel),
235
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 33 New Guy | | New Guy Joined: Dec 2011 Posts: 33 | Hello - my truck came with a muncie three speed trans and I am looking for information on it - ratios, type of trans oil, how to service and check fluid levels etc. Any help is appreciated | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you'll want to get a shop manual for your year to always have info like that at hand, the glovebox manual and the assembly manual will also be useful if you plan to have the truck long
Bill | | | | | Joined: Dec 2011 Posts: 33 New Guy | | New Guy Joined: Dec 2011 Posts: 33 | I will ook around and try to find one. I do have a follow up questiosn though. As this is not a stock trans for a 52 suburban, do i fill the diferential separately now or do the trans and dif still share oil? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year and model transmission do you have?
| | | | | Joined: Dec 2011 Posts: 33 New Guy | | New Guy Joined: Dec 2011 Posts: 33 | I am not sure of the year yet but it is a Muncie three speed> I assuem you are asking because different years will dictate whether or not the oil is shared, correct? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | do you still have the torque tube arrangement? if yes, the trans is the same as original, if no, then there's no connection between the trans and rear .... you can track down info here, even if not for your exact year Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The trans & rear end do not share the grease. They are checked & filled separatly. Often the seal in the rear of the tran is bad & the grease can run from the trans back to the rear end. If thats the case you will need to drain the excess out of the rear & refill the trans. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
