2 members (R&S 51 GMC, Bill Hanlon), 90 guests, and 3 robots.
Topics128,125
Posts1,056,338
Members48,440
Hello - my truck came with a muncie three speed trans and I am looking for information on it - ratios, type of trans oil, how to service and check fluid levels etc. Any help is appreciated
you'll want to get a shop manual for your year to always have info like that at hand, the glovebox manual and the assembly manual will also be useful if you plan to have the truck long
I will ook around and try to find one. I do have a follow up questiosn though. As this is not a stock trans for a 52 suburban, do i fill the diferential separately now or do the trans and dif still share oil? Thanks
What year and model transmission do you have?
I am not sure of the year yet but it is a Muncie three speed> I assuem you are asking because different years will dictate whether or not the oil is shared, correct?
do you still have the torque tube arrangement? if yes, the trans is the same as original, if no, then there's no connection between the trans and rear .... you can track down info here, even if not for your exact year
Riding in the Passing Lane
The trans & rear end do not share the grease. They are checked & filled separatly. Often the seal in the rear of the tran is bad & the grease can run from the trans back to the rear end. If thats the case you will need to drain the excess out of the rear & refill the trans.
1972 Chevy c10 Cheyenne Super
