2 members (texczech, Peggy M),
100
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,427 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Once again, I'm appealing to the collective knowledge and good will of fellow 'Bolters...
If someone out there has a GM master parts book that encompasses '67-'72 Chevy & GMC trucks, I am seeking the following info:
"What column shift linkage rods fit which trucks...'67 - '72 ?"
Am working on my 1972 Chevy C-10, 2wd, lwb(127")pickup, w/ 250 straight six, and three-speed tranny. When I got the truck, the column shift had been disconnected, and replaced with a junky floor shifter, which disintegrated shortly after Thanksgiving.
After looking locally, I finally contacted Jim Carter, and they said they had a truck with said linkage, so I ordered it, it arrived, looked ok (but I never saw the originals, so what did I know??). Went to put 'em on the truck last Saturday when the temp crawled up into the low teens, and .... THEY DIDN'T FIT !!! They seemed to be a bit too short and also struck to toe-board when positioned to where they would've run if they were the right legnth. I went by the factory shop manual for adjusting the column linkage- setting the column levers at neutral using a gauge rod through the levers, etc.; the cab doesn't seem to have collapsed on its mounts, etc....and I was using what I believe are the original tranny side levers, which I found in the glove box, not the goofy fitzall levers that went with the floor shift.
What I want the parts book reference for is to know whether there are different rods for 6 & V-8 trucks, long vs. short wheelbase, 2wd vs. 4wd, model year, etc. or if the shifter rods from any '67 to '72 GM truck with column shift will work....
So, if someone out there can look this up.... I'd sure appreciate it !!!!
Thanks for the help!
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | If you had to re-install the shift levers on the tranny, make sure you got them positioned right on the shift shafts. I had a similar prob when I rebuilt the 3-speed on my 54 chevy. I got the shift levers re-installed wrong, and it wouldn't shift, the shift rods wouldn't fit, etc...
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Chip head,
I tried all possible ways, then looked in the shop book, and it's picture showed 'em both pointing towards the ground, and slightly forward.
Tried that too, but rods no reachee....
So, back to my initial question: parts book, anyone ? Pleeeeeease ?
