8 members (David Bush, kades51, BC59, MikeE, Bucker, MickeyP, Rexville48, dt235sd),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 |
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Jim carter lists them as 1947 to mid 1952.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2011 Posts: 6 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 6 | I have the same window locks on my 53
53 Chevy Suburban restoration, been in family since 54
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Tim is correct, according to someone else on the board, these were for the 1947/52 suburban 53 was different and 1954/55 were another design. I have never seen the 1953 style, so I cannot confirm the differences. I have seen the others. Mike at oldtrucks might be able to help. | | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | My 49' has the straight style locks that catch on the stainless trim tab to lock the window. I purchased some from Jim Carters last year that did match my og locks.
These have bends on the top where they would catch the trim or window... I always assumed they were for the later 55-59 burbs but found that the mounting screws are in a different location | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | They are mid 1952 - 1955 1st | | |
