Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Pre '68 Dave, 55shaker), 110 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
HI All,
"IF" one were to replace a bum transmission in a 235/55 1st 3100 truck and they wanted a floor shift which number Saganaw would one be looking for... a direct replacement of course... three speed or four and how much should one pay for said item? T/C Steve :whistle:
Patrick dykes suggests the 3.11 first gear Saginaw, identified with 2 grooves on the input splines. Shouldn't be much more than about $100.
Bill Burmeister
Bill...would there be any other stamp or description on the case as I would be looking for one through ebay and really don't know what I'm looking for or what to ask for....Thanks for the help and T/C Steve
The 4 speeds that came in vegas, sunbirds, starfires amd monzas from 73 on were saginaws with 3.11 low gear. I bet ther5e are a ton of them out there still.
mv
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
Hi Who me,
I have a saginaw 4 speed and the Patrick's shifter I never used. I was going to use it in my 46 1/2 ton. I have decided to go with a t-5. It is an easier swap for my truck. Any way I would be willing to sell the saginaw cheap. It is the 3:11 1st gear just what you are looking for.
got one in SF. at least I think I do. I know it is a 4 speed side shifter. I don't have the hurst type linkage.
