0 members (),
87
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82613 09/06/2007 7:31 PM | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | im planning to relocate the gas tank to the rear of my 48 3/4 ton running a 235. Im going to be mounting this: http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D290108&N=700+115&autoview=sku behind the rear axle. my question is what size fuel line should i use, 3/8 or 1/2in.
also where is it best to put the fuel filter, i imagine before the pump, am i correct. | | |
#82614 09/06/2007 7:59 PM | Joined: Aug 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 33 | 3/8" fuel line should be plenty. Actually, I have had quite a few V8 vehicles over the years that only had 5/16" line from the tank to the pump. And, I always try to run a filter before the pump, but typically also run one between the pump and the carburetor. | | |
