3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#82613 09/06/2007 7:31 PM
im planning to relocate the gas tank to the rear of my 48 3/4 ton running a 235. Im going to be mounting this:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D290108&N=700+115&autoview=sku
behind the rear axle. my question is what size fuel line should i use, 3/8 or 1/2in.
also where is it best to put the fuel filter, i imagine before the pump, am i correct.
#82614 09/06/2007 7:59 PM
3/8" fuel line should be plenty. Actually, I have had quite a few V8 vehicles over the years that only had 5/16" line from the tank to the pump. And, I always try to run a filter before the pump, but typically also run one between the pump and the carburetor.
