| | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 18 New Guy | | New Guy Joined: Jan 2012 Posts: 18 | I have a 45 Maple Leaf two ton I am redoing from the ground up. My wheels are 5 stud and most are 6 stud. Is this a good or bad thing or is there any wheel that I can replace that with? | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Welcome to stovebolt.com. I can't answer your question as not familiar with the differences between maple leafs and US chevys and GMC's. Thru the early fiftys it seems more common for chevys to have the 5 stud on steer and 10 stud on rear. Some GMC's and late fiftys chevys had the 6 stud wheel. Which is better? I expect you will get answers on both sides. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ralphie, welcome, the lightest Maple Leaf would be a 2 1/2 ton, does your serial number begin 516.....? The 2 1/2 ton Maple Leaf is Chevrolet powered, the 3 ton is GMC powered. Maple Leaf trucks use Motor wheels, while Chevrolet trucks use Kelsey wheels, hope that helps. | | | | | Joined: Jan 2012 Posts: 18 New Guy | | New Guy Joined: Jan 2012 Posts: 18 | My truck is a Maple Leaf two ton (or so I thought) with the serial number that begins with 516. My truck has Kelsey wheels. My GVW is 10,900. Does that make it a 2 and a half ton? | | | | | Joined: Apr 2004 Posts: 5,070 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,070 | If you want to know ANYTHING about Maple Leaf trucks, you need to contact Rick and Tara Higgins. Their Gallery page is practically a Tech Tip already ... but truly have one in progress. It's so huge, it's about two years old. I have referred anyone who comes knocking at HQ asking about Maple Leaf trucks to them. Turns out (this is strange), most of the people who have come here, LIVE right near the Higgins. Ain't Stovebolt World great. Give them a try. Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Speaking of Maple Leaf's. I found a late '30's model Maple Leaf down hear in North Carolina some years ago. Always wondered it's history, of how it got this far south. I need to find out if it's still there. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Speaking of Maple Leaf's. I found a late '30's model Maple Leaf down hear in North Carolina some years ago. Always wondered it's history, of how it got this far south. I need to find out if it's still there. It likely went south for the winter to escape the cold and ended up staying. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ralphie, if you could post your serial number I could decipher it for you, but if it begins 516 then it is definately a 2 1/2 ton, powered by a 224 cu. in. Chevrolet engine, and it should have five bolt Motor wheels all around. Who knows what components may have changed over the years, maybe a Maple Leaf cab was swapped onto a smaller chassis? | | |
