| | | Forums66 Topics128,085 Posts1,056,329 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Need a measurement to re-install my spare tire carrier. The center board of the 46 half ton has a couple holes about mid way to locate the mounting of the spare carrier. Problem is that these holes are not centered front to back and I'm thinking a bit closer to the back, but need to measure exactly. So if anyone out there has an original bed with these holes I'd appreciate a little help locating these holes. Thanks Jim | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I just went out to the garage and measured my 46. My truck was restored by the prior owner. The 3 bolts are 36 1/2 inches from the back edge of the bed. (from the center of the bolt head) The position allows the J hook that bolts to the spare carrier to hang straight down from the back bed frame rail. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Many thanks Dave, just what I needed. Jim | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | | | |
