| | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | I'm getting my truck ready to have a friend blast my 65c10. Started taking apart my doors.Can't figure out how to get the glass and everything out.Need help! | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | have to take all outside bolts out, including vent window. remove bolts from regulator travck at bottom of window and take door glass out. then take out regulator. there is a slightly wider area between the outside and inside of the door just behind the vent latch so vent window will have room to come out. | | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | Thanks,I guess my problem was the window crank was stripped...used vise grips to crank...but still seemed jammed.After a little swearing,and patience...I got the job done.The second door was a bigger since the latch screws were welded to the door...more swearing. Thanks for your help! | | |
