| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82582 09/05/2007 9:38 PM | Joined: Aug 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 33 | My 49 3100 has recently developed a fairly bad driveline vibration. It seems to be more speed related than rpm related. In other words, you can be driving along at a certain speed (40 for example) when the vibration gets fairly bad, push in the clutch and let the engine idle, but the vibration remains fairly constant.
It has a 235, 3-speed and still has the enclosed driveline. I at first thought that clutch or pressure plate could be the problem, but wondered if something else could possibly be causing the vibration.
I have worked on plenty of open drive line pickups, but the torque tube is all new to me.
I do have an open rear end out of a first series 55 that I plan on installing at some point, but it may be a while. So, I would just like to keep it driveable until then if the problem is not too involved (and costly) to fix.
Any ideas?
Thanks in advance, Jeff | | |
#82583 09/05/2007 9:41 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds more like a tire/wheel problem. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#82584 09/05/2007 9:49 PM | Joined: Aug 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 33 | After reading back through what I wrote, it does start to sound wheel/tire related. However, I did recently check all the wheels for straightness, put on new tires and had them balanced. The vibration has gotten incrementally worse over time after changing out the wheels and tires (but that is also when I started driving it on paved roads). I may be wrong, but it seems to be final drive related, but I do need to check the wheels/tires/wheel bearings again.
Thanks for the comment. | | |
#82585 09/05/2007 10:39 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | It could also be a u joint or an okie bushing going bad. By pushing the clutch in you ruled out the engine and transmission. | | |
#82586 09/05/2007 11:48 PM | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | You my have lost a weight off one of the wheels If you feel the vibration in the steering wheel,it's in the front If you feel it in the seat,it's in the back. Put the back wheels on the front,etc. see if the vibration moves. | | |
#82587 09/06/2007 1:28 AM | Joined: May 2002 Posts: 23 'Bolter | | 'Bolter Joined: May 2002 Posts: 23 | | | |
#82588 09/06/2007 4:26 AM | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Uh oh, accidental double post...........
1948 AD Pickup
#82589 09/06/2007 4:27 AM | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Put me down with the others for u-joint. I had that happen on my CJ and it vibrated the cigarettes butts out of the ashtray at certain speeds.
1948 AD Pickup
#82590 09/06/2007 12:13 PM | Joined: Aug 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 33 | Thanks for all the replies. I crawled under it last night to verify that I didn't pitch a wheel weight since I had just had the tires mounted and balanced fairly recently. It appears that they are all there as best I can tell. I did not see any signs of areas where a weight was (powder coat scratched). I am leaning toward a u-joint and will check that as soon as I get a chance.
Thanks again, Jeff | | |
#82591 09/17/2007 12:57 AM | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | did you check the driveshaft support? I'm about to replace mine, the bearing is suspended in rubber that has suffered from serious dry-rot. 25 bucks at classsic parts, $11 at the local autoparts. | | |
