8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible), 181 guests, and 2 robots.
Topics128,086
Posts1,056,094
Members48,434
#825709 02/13/2012 3:56 AM
i cant get the rear brake drum off what should i do
Turn the adjustors, to bring the shoes in.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
adjustor seems to be seized
back yard wrench turner
Use penetrating oil, back off the adjusters then smack the drum with a hammer to loosen the shoes.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
mo Offline
the drum is probably stuck to the hub by rust. try beating the drum between the wheel studs with a bfh. they also like to stick around the center. if that is the case you can try heating it up around the center and also around the studs. you will hear a pop if it comes loose this way. heating is kind of a last resort so be very careful if reuseing the drum.
MO's 1951 chevy 3100 resto mod project
is backing off pushing adjustor spocket in a up direction
It depends on which side (front or back) you are looking at. Have a look in the shop manual, and it will tell you which way to go.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Look in the adjuster hole and see if you can see the threads. Then you can work out which way to turn it depending upon which side the wheel is on.
Fact is, since no doubt the shoes are worn and it hasn't been adjusted in a while, you could try turning it either way to loosen it up.
Kurt
