1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#825362 02/12/2012 4:58 AM
Hey guys, I pulled the cab off my 55 2nd series 6100 and when I put it back on I noticed something wasn't right. I used a 1/2 ton mounting kit not knowing that the rear mounts are different. I checked my assembly manual and now know what I need. I just don't know where to get the correct cushions. The old ones are in bad shape and only one of them is correct. Any ideas or do I have to make them? Thanks! SEE YA! Mark
1955 Chevrolet 6100 Wrecker
More pix on Flickr
"A good mechanic doesn't know everything, but he can figure out anything". ~ --My DAD
1955 Chevrolet 6100 Wrecker Video
1955 Chevy 6100 Wrecker Update Video
og55 #825627 02/12/2012 11:38 PM
Mark,
I had to make them for my 10500 series fire truck. They are 1-1/2" thick, so I went to my local industrial rubber supplier and got a piece of scrap that they use for snow plow cutting edges. I used a hole saw in my drill press to make them round. The edges aren't smooth like original, but they work! My truck required 4 pieces, one on top and one under the bracket on each side.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #825638 02/12/2012 11:59 PM
Good tip Mike I may need to do that my self.
If a guy has to have them smooth or shape them you could dip them in liquid nitrogen to freeze them and use a belt sander. We even shaped rubber parts by freezing them and turning them on a lathe.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Thanks Mike, I kind of figured I'd have to make them. I'm going to try cutting them on the CNC. If I can find the rubber. See ya! Mark
More pix on Flickr
og55 #825782 02/13/2012 2:27 PM
Unless it's really hard or frozen rubber doesn't machine....
I've made nice holes and rounds in rubber with a sharpened thin wall tube spinning in the lathe and press the rubber onto it using dish soap as a lubricant. Sort of like combining the best of a hole saw and a hole punch all in one.
I bet you could have them water jet cut with good results.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #825958 02/14/2012 12:52 AM
Hey Grigg, we've cut rubber on the CNC many times ,if you have the right tooling & right programing it works well. No freezing required. I just have to find the rubber . See ya! Mark
More pix on Flickr
og55 #825985 02/14/2012 2:09 AM
Camp Commandant
Camp Commandant
Grigg, Mark, Mike,etc., I too need to make new mounts for my 860 and of course went to my McMaster Carr catolog. I get confused with all the durometer ratings. I have bought rubber for other porjects and using their scale as a guide have still come up buying something a little too hard or soft.
I guess that is my fear, buying something that is one way or the other for a cab mount. Grigg, do you have any words of wisdom for making my selection.
Hope I am not stealling this thread. My add would be, as always, MC is a great resource for finding bits and pieces for a resto or build.
~ Billy
1959 GMC 860 | Pictures
Billy,
It's difficult to pick the right one without dealing with rubber every day (I don't either) I've found the little comparison scale McMaster has in the catalog very helpfull before. The one where they show erasers, shoe soles, bowling balls and such as comparable to what durometer numbers.
http://www.mcmaster.com/#about-firmness-ratings-for-rubber/=g8tfpm
I'd guess for cab mounts you want something in the "Med. Hard" range.
Mark, curious to know more about how you machine rubber, what sort of tools? I've tried it on occasion with my manual machines and can usually come up with what I need in the end but it never works out how I expect, it's tricky... the soft stuff never works for me unless frozen or simply cut/sheared/punched and not machined.
Grigg
---All pictures---
Hey Grigg, we use a single flute straight cutter designed for rubber. If I find the rubber I'll do a video of cutting it. See ya! Mark
More pix on Flickr
og55 #831682 03/03/2012 12:34 AM
Hey guys , Here's an update on what I decided to use for my cab mounts. I was looking online for rubber and had no luck. I read Bill's post on McMaster - Carr and gave that a look. Thanks Bill! The flat stock seemed too expensive. Sorry Grigg no CNC video! I saw they had rubber tubes so I explored that route and bought a 6" piece- part # 8637K311photo, it is 2 1/2' OD[that's 1/4" larger than original] with 3/4" ID and a 75A durometer rating[ that is considered a hard rating].It is neoprene & is oil, impact & weather resistant. I had one original cushion & compared it to the new rubber & the hardness seems very close. It cost $17 with shipping. The cushions need to be 1 1/2" thick so 6" was just enough. I cut the rubber into 4 - 1 1/2' pieces on my bandsaw photo. I also bought 2 - 7/16"-14 X 6" grade 5 carriage bolts,the manual shows hex head bolts photo - exploded view,but my cab had carriage bolts and that looks correct. Lastly I needed the spacers & washers which I was lucky enough to find some scrap tubing & flat stock at work.The spacers are 3/4" OD X 1/2" ID X 2 7/16" long photo. For the washers I used 3/16" flat steel [3/16" is a little too thick but that's all I had] and cut them out with a 2 5/8" hole saw, that gave me a 2 1/2" OD. I then drilled the center out to 1/2" photo. I hope to install everything soon. I guess only time and driving the truck will tell if it all works properly. SEE YA! Mark
More pix on Flickr
og55 #831718 03/03/2012 2:39 AM
og55,
Thanks for the update!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
