1 members (Alex52), 136 guests, and 5 robots.
Topics128,186
Posts1,057,211
Members48,465
only driver rear wheel will turn by hand and the other side will not move at all is this a posi or is the passenger side stuck
If you can turn it, and the other side does not turn the same way, it's most likely not a posi.
Bill Burmeister
one side will not move at all
You may have a stuck brake. However, since you can turn the drivers side, that points to the differential not being a posi.
Bill Burmeister
any idea how to release a stuck brake
If you can get to it, back the adjuster off. Then, if the drum doesn't turn free, try rapping the outer diameter of the drum with a hammer, that will usually make the shoes release from the drum. You'll definetly want to take a look in the brakes to see if there's any issues, like wheel cylinder leackage or broken/damaged hardware.
Bill Burmeister
its a 12 bolt rearend i guess it would be wise to install a posi and rebuild everything
its a 12 bolt rear end i guess it would be wise to install a posi and rebuild everything
thanks you seem to know alot about the 12 bolt rearend any suggestion on upgrades, axle housig Id 3856526
