2 members (Wayne67vert, Wally / Montana), 309 guests, and 8 robots.
Topics128,087
Posts1,056,112
Members48,434
#825154 02/11/2012 7:29 PM
I am working a 1949 chevy P/U which I purchased I need to know what size fuse goes in the fuse holder. The fuse holder has 5 fuses H beam, L beam, Park,Tail and Stop fuses. What size fuse should be in each one. I found a bag of fuses that came with the truck. Buss SFE 20A, Buss AGC 30, and SFE 14 also is there a inline fuse for the gas gauge? I bought a voltage reducer for the gas gauge and the directions for installation shows an in line fuse attached to the gas guage. I looked in all my manuals and cannot find any info about fuse sizes. The truck was converted from 6 to 12 volt when I bought it.
Bennie
Riding in the Passing Lane
Generally headlights don't use fuses. Put 30 amp in the high & low beam. 10 amp in the park & 10 amp in the tail lights & 15 amp in the stop.
1972 Chevy c10 Cheyenne Super
Thanks for your help
Bennie
Don't know if this will help, but this is pages 57 & 58 from the
1948 truck operators manual, 1949 schematic should be the same.
Call out for all the fuses is 20amp.
http://www.pbase.com/dennygraham/image/141450842/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Fuses keep wires from burning up, so just size the fuse to the wire. 10AWG=30A, 12AWG=20A, 14AWG=15A, 16AWG=10A. A good 'all-purpose' size is 10 amp for electronics or 20 amp for bulbs. Either will blow in a short circuit and that's what you want.
Thanks Denny this is just what I needed the picture with the fuses is the same as I have installed in my 1949. Oh by the way when can we meet to talk about your 54 and my 49. I have been reading the post about the front and rear motor mounts this sparked my intrest to checking out both. At first I was just looking to replace the two carriage bolts. Denny I live in South Elgin, Il not that far from Sandwich, Il
Bennie
check you PM's Bennie.
DG
Denny G
Sandwich, IL
