7 members (Shardean, DannyW, 68ironhead, Eisenholtz, 3800GUY, Shade Baby, cmayna), 40 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#82521 09/04/2007 5:10 PM
Anyone have any hints on how to install the plug that is to the rear of the egine, on the side, under the manifold on a 58-62 235? I got the front one in but this other is killing me!
#82522 09/04/2007 9:14 PM
There are plugs that intall in the hole and tighten with a center bolt. The are a combination rubber and steel plug. I have used them in just the same area as you are refering to. The challenge is getting the old one out.
#82523 09/04/2007 9:16 PM
Thanks for the reply Lonnie,
I got the old one out with much effort. I replaced the one near the front of the engine but the other is bit tougher to reach and get any leverage. I was hoping for a trick other than pulling the engine. Good to know their is a solution that you used. I will have to get one and save my knuckles.
#82524 09/05/2007 2:14 AM
i think they sell a freeze plug installer kit. it looks like it could be used from a angle. i have never used it myself. only replace mine while engine is out and in process of rebuild. i always just drive them in with best sized socket. hr
#82525 09/05/2007 4:26 AM
Those freeze plug installers work great
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#82526 09/05/2007 5:48 AM
Are you trying to do this with the manifold on or off? I would just pull the manifold for better leverage, its not too hard to re-install.
Paint & Body Shop moderator
#82527 09/05/2007 2:49 PM
The manifold is on, that probably will be my next move is to remove it and then it shouldnt be as big as issue. Just trying to avoid work!
