1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82521 09/04/2007 5:10 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | Anyone have any hints on how to install the plug that is to the rear of the egine, on the side, under the manifold on a 58-62 235? I got the front one in but this other is killing me! | | |
#82522 09/04/2007 9:14 PM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | There are plugs that intall in the hole and tighten with a center bolt. The are a combination rubber and steel plug. I have used them in just the same area as you are refering to. The challenge is getting the old one out. | | |
#82523 09/04/2007 9:16 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | Thanks for the reply Lonnie, I got the old one out with much effort. I replaced the one near the front of the engine but the other is bit tougher to reach and get any leverage. I was hoping for a trick other than pulling the engine. Good to know their is a solution that you used. I will have to get one and save my knuckles. | | |
#82524 09/05/2007 2:14 AM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i think they sell a freeze plug installer kit. it looks like it could be used from a angle. i have never used it myself. only replace mine while engine is out and in process of rebuild. i always just drive them in with best sized socket. hr | | |
#82525 09/05/2007 4:26 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Those freeze plug installers work great | | |
#82526 09/05/2007 5:48 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Are you trying to do this with the manifold on or off? I would just pull the manifold for better leverage, its not too hard to re-install.
#82527 09/05/2007 2:49 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | The manifold is on, that probably will be my next move is to remove it and then it shouldnt be as big as issue. Just trying to avoid work! | | |
