| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | i picked up a complete a292 eng.my quistion is,,will the manifolds fit my 250 chev eng?thanks guys you alsway come thru, | | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | Yes they will as long as your 250 doesn't have the intake cast into the head. If it does, swap the whole head and manifolds.
Joe | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | There may be a difference in the angle of the exhaust pipe off the manifold depending on which 292 manifold you have, an easy fix.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
