6 members (FishinToms53, 1955 1 Series, baldeagle, KEVINSKI, Gdads51, Peggy M), 90 guests, and 1 robot.
Topics128,052
Posts1,055,740
#817981 01/20/2012 5:10 AM
I
I Offline
Does anyone know what 6 cylinder engine came in a 63 1/2 ton?
I believe that the 235 ended in 1960 but don't know for sure
the 235 went until 62, with some available in '63 I've heard - after that the 230 was standard and a 292 would have been the optional 6
yeah, the 235 went to 62...the 230/292 went to 65 then they went to the 250/292. Chevy also lists the 194 in the 63 book, but I have never seen one installed in a truck. i believe most of those went to cars and maybe the corvair trucks.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
235 went thru 1962 and into 1963 in K series vehicles.
BC
1960 C60 pasture art
The 194 was primarily a Chevy 2/Nova, and later is saw use in the Chevelle/El Camino/G 10. The Corvair used a completely different engine, a horizontally opposed 6 cylinder, not shared with any other GM vehicle line.
Bill Burmeister
I believe the 153 and 194 only showed up in vans in the truck series.
My Blog
I've got a '64 C-10 LWB Step Side that has what looks like the original tiny Radiator still in it. I always believed that it was possibly an original 153, or maybe a 194 truck.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
The 153 is a 4 cylinder engine.
The 230 could come from the factory with the small radiator
My Blog
The 194 was primarily a Chevy 2/Nova, and later is saw use in the Chevelle/El Camino/G 10. The Corvair used a completely different engine, a horizontally opposed 6 cylinder, not shared with any other GM vehicle line. [/quote]
Corvair used air cooled engines.............
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
The 63 chevy truck Shop manual does list a 4cyl 153cu in engine also. Rated at 90hp and 152# torque
Corvair trucks never used the stovebolt six. They used the same basic engine as the Corvair car: 145/164 cid flat six - air cooled.
My 63 C-10 has the original 230 base engine , so unless the engine was an upgrade option that is likely what it was.
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
There were also 2 different version of the 230 in 63. One was an economy version lower Hp/torque
Only the 235 in the K series
230 in mine with a BIG radiator.
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
