7 members (MRMEROTH11, FAST55, Otto Skorzeny, Hotrod Lincoln, carbking, TUTS 59, Joe H),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Does anyone know what 6 cylinder engine came in a 63 1/2 ton?
I believe that the 235 ended in 1960 but don't know for sure
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 235 went until 62, with some available in '63 I've heard - after that the 230 was standard and a 292 would have been the optional 6
Bill | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | yeah, the 235 went to 62...the 230/292 went to 65 then they went to the 250/292. Chevy also lists the 194 in the 63 book, but I have never seen one installed in a truck. i believe most of those went to cars and maybe the corvair trucks. | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | 235 went thru 1962 and into 1963 in K series vehicles.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | yeah, the 235 went to 62...the 230/292 went to 65 then they went to the 250/292. Chevy also lists the 194 in the 63 book, but I have never seen one installed in a truck. i believe most of those went to cars and maybe the corvair trucks. The 194 was primarily a Chevy 2/Nova, and later is saw use in the Chevelle/El Camino/G 10. The Corvair used a completely different engine, a horizontally opposed 6 cylinder, not shared with any other GM vehicle line.
Bill Burmeister | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I believe the 153 and 194 only showed up in vans in the truck series.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | I believe the 153 and 194 only showed up in vans in the truck series. I've got a '64 C-10 LWB Step Side that has what looks like the original tiny Radiator still in it. I always believed that it was possibly an original 153, or maybe a 194 truck. Bill
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 153 is a 4 cylinder engine. The 230 could come from the factory with the small radiator
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | The 194 was primarily a Chevy 2/Nova, and later is saw use in the Chevelle/El Camino/G 10. The Corvair used a completely different engine, a horizontally opposed 6 cylinder, not shared with any other GM vehicle line. [/quote]
Corvair used air cooled engines.............
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | The 63 chevy truck Shop manual does list a 4cyl 153cu in engine also. Rated at 90hp and 152# torque
| | | | | Joined: Jun 2006 Posts: 10 New Guy | | New Guy Joined: Jun 2006 Posts: 10 | Corvair trucks never used the stovebolt six. They used the same basic engine as the Corvair car: 145/164 cid flat six - air cooled. | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | My 63 C-10 has the original 230 base engine , so unless the engine was an upgrade option that is likely what it was. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | There were also 2 different version of the 230 in 63. One was an economy version lower Hp/torque | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | Only the 235 in the K series | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | 230 in mine with a BIG radiator. 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | |
