2 members (cmayna, CuzzFuzz),
60
7
Mod | | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 49 | From what I have read in the form a 1960 235 ci will fit in a 1951 pickup. The front motor mount has only one bolt in it. The 1956 engine I have in it has two (when I got it). I just wanted to check with the form before I buy the motor to rebuild. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A 1960 235 will fit in a 1951 pickup. Someone else will have to reply about the front motor mount (all of mine in 1/2 ton trucks have two bolts in the front motor mount). The '60 engine's front plate can be easily adapter/drilled in order to get it to work.
You will need to use your '51's clutch housing and, if you will run at 6v, your will need the '50 flywheel and clutch assembly.
Also, you will have to deal with the longer (to the front) water pump on the '60 engine. The options for the water pump are: - buy a short-shaft water pump with the correct pulley groove($$$), or - get a pulley with the right groove and push in onto the '60 water pump and cut off some material off the pulley post, or - buy a relocation plate and drill a few holes in the block (this allows you to use your '51 water pump).
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | If you are going to rebuild it then you can install any plate you want. I would be interested in the mount if it's in decent shape and the plate if you swap it out rather than modify it. I've got a '54 261 (high mounted pump block) that I've got rat-holed ,hope to find a nice AD pick-up that needs an engine. Don't think the wife is in the loop on this part!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | [quote=BC59 Don't think the wife is in the loop on this part! [/quote]
It's best to keep it that way until you are parking it in the driveway. :>)
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
