| | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Almost finished re-wiring my truck and was wondering about the license plate light pictured below. The lens is missing and when I went to look for one among the typical vendors, I didn't find anything at all similar, which makes me think this is probably an after market item. Does it look familiar to anyone? [IMG] http://i7.photobucket.com/albums/y261/bohon/56%20Chevy%20truck/TransandDome013.jpg[/IMG]
1956 Chevy 3200
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | an odd aftermarket item or an interior light from something - the license light in 56 was part of the single tail light - if you want to use it you might find something at Taillight KingBill | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Thank you. I'll look there.
1956 Chevy 3200
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | here's another thought - license lights are legally supposed to shine on the plate only, not to the rear of the vehicle - the way that light is mounted would seem to have had a red lense as a tail or aux brake light
Bill | | | | | Joined: Aug 2011 Posts: 5 New Guy | | New Guy Joined: Aug 2011 Posts: 5 | It looks like a Betts Ind. light.
Clear lens would be 920048 or 920057 for a tall reflectorized style | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | So is it actually a license plate light? Where are the part numbers you mentioned from?
1956 Chevy 3200
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No, it is not a license plate light. If you put a clear lens on that and use it for a tag light you are asking to be pulled over. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | looks like a running "marker" light base that goes on a trailer,just my opinion.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2011 Posts: 5 New Guy | | New Guy Joined: Aug 2011 Posts: 5 | It is basically a running /marker light. I got the part numbers from the Betts catalog (bettsind.com). We used them for trailer lights. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Thanks. I've since replaced it with a real license plate light.
1956 Chevy 3200
