5 members (Jon G, baldeagle, Nick in Manitou, TexasJim50, Woogeroo), 66 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#824026 02/08/2012 4:53 AM
Hi:
I'm new to this forum. I just picked up a 62 Chev with a 235 and 3 speed manual. The speedo wasn't working when I got it and I found the driven gear was missing from the transmission. Of course it was extra long and a tough one to find.
Anyway, now I've got it all working, but in the morning, when it's really cold, my speedo makes a horrible whining sound and the needle goes crazy - up to 100 and down to zero and back.
Anyone got any ideas what's going on and how I can fix it?
Thanks!
Glen
Glen_P #824030 02/08/2012 5:00 AM
The bushing the speedo is binding. Best fix would be to replace the speedometer head.
Bill Burmeister
LONGBOX55 #824033 02/08/2012 5:10 AM
Thanks Bill.
Any idea where I get one and is it expensive?
Glen_P #824040 02/08/2012 5:22 AM
You might check with some of the parts suppliers in the Links section. There's several of them that offer discounts to Stovebolt members. I had to replace the one in my '55, I seem to recall it was around $100 for a new speedo head. That did include the odometer, needle, and high beam indicator.
Bill Burmeister
LONGBOX55 #824045 02/08/2012 5:38 AM
Looks like I may have spoken a little too quickly. Just from my quick search of 4 of the companies, only 2 list your speedometer. Seems it's only available as a reman, and it's around $200. Jim Carter was the higher of the 2, with no mention of a core, American Classic has is for about $15 less, but charge $50 if you don't sent in a core.
Bill Burmeister
LONGBOX55 #824047 02/08/2012 5:43 AM
Thanks Bill. Here I go on another quest. smile
Glen_P #824086 02/08/2012 1:23 PM
Try pulling the cable out of the sheath and coating it with grease. This works every time for me to calm a jumpy speedo.
George
Napco Man #824235 02/08/2012 9:45 PM
If only does it when cold a good clean & lube both cable & head should do the trick.
BC
1960 C60 pasture art
BC59 #824344 02/09/2012 3:50 AM
Thanks for all this advice guys! I'll start with a clean and lube and work toward more expensive alternatives as this unfolds.
Glen
Glen_P #824377 02/09/2012 5:19 AM
George, I put this on my list of things we can discuss. I do not have a good idea of what you mean.
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone #824437 02/09/2012 2:12 PM
Over time, the slip-shaft inside the speedo cable jacket, gets corroded. I have found the best way to thoroughly lubricate a speedo cable is to spool it up and drop into a pan of ATF or clean motor oil and let it sit overnight. After a thorough soaking & wipe-down, install it. You won't have the objectionable noise any longer.
