| | | Forums66 Topics128,162 Posts1,057,040 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Wow, that is something else. What year(s) would this be from?
Thanks for sharing pics of your cool stuff Brad, much of it I suspect I'll only ever see pictures of! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It is interesting to see that it is a "universal" radio. That means that Delco was in the business of making radios to put in any vehicle. I am going to guess that mode of marketing didn't last too long. The radio case looks a little small to be complete for the period. I am wondering if it has a separate power supply. | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Could someone explain how that would fit on the column? I see how the arm would fit, but that big brown box...not so much.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not to surprised since Delco was into the home radio market also Fred. Had a couple of them over the years. This one probably used the same circuits as the standard GM accessory radios.
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Says for the years 1941-42 and 1946-47 Pontiac and Chevrolet. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | The brown box would mount under the dash.
Pretty amazing this NOS stuff is still around. | | |
