1 members (baldeagle), 37 guests, and 6 robots.
Topics128,014
Posts1,055,327
Members48,419
#823405 02/06/2012 3:54 AM
I have just started on a 1956 3600. I'm in the process of rebuilding the front end. Will hurt anything to heat axil in order to remove the king pins?
Benji
I'm not lost, I'm exploring.
Welcome aboard!
Might be better to pull the axle and take it to your local automotive machine shop. I had my '56 GMC 1-ton (same as 3/4) axle done just a few weeks ago.
I couldn't move the kingpins at all with my 10-ton press so I took the axle with spindles attached and a new set of kingpins and and had the axle plus fitted spindles back just a few days later for around $60.00. The machinist said his press was rated at 50-tons.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
3B Offline
Hy benjikeel, welcome, it is not acceptable to use heat (excessive) to dismantle any steering components, unfortunately most people don't know the difference between excessive heat and acceptable heat, so I tell everyone not to use heat.
3B #823463 02/06/2012 12:12 PM
Agree with that 100% Ben, no heat on forged steering or suspension items. If it's that tight get some hydraulic help.
DG
Denny G
Sandwich, IL
All good advice, nuff said...
~Jim
Thanks for the info, hope to get some pictures up soon.
Benji
Alright! The king pins are out! Thanks for the advice and thanks to my dad for teaching me how to swing a sledge hammer.I heated them enough to burn the grease and gunk off pretty good, and with alot of grunt, they finally moved.I'm sure I'll be back with more question as this project goes along.
Benji
