5 members (Peggy M, manymiles, Hanks custodian, Gdads51, mick53), 100 guests, and 3 robots.
Topics128,151
Posts1,056,989
Members48,460
#823148 02/05/2012 9:45 AM
To me all of the 1960-66 Chevy pickups look to be the same size.However some are listed as "1/2 ton" or "3/4 ton",etc..So my question is,is there any difference in size between the 1/2 and 3/4 ton trucks?
Thanks!
"Size".. the answer is yes and no
"Yes" in regards to the size of suspension components. (6-lug vs. 8-lug wheels, larger springs, etc.)
"No" in regards to the overall size of the truck.
There were no short wheel base (115") 3/4 ton trucks, so they do appear a bit beefier with the slightly larger tire/wheel diameter & 8 lug rims. The sheet metal is interchangeable between the C10 (1/2 ton-2wd), K10 (1/2 ton-4x4), C20 (3/4 ton-2wd), K20 (3/4 ton-4x4) & C30 (1 ton-2wd), so they do look, somewhat the same size, at first glance.
The 3/4 and 1 ton trucks also have thicker frames. the one ton,s have a leaf spring,s with overloads on the rear.
Excellent.Thanks for the replies!
One more question: One of the trucks Im thinking of buying has an 8 foot bed.Would this be the long bed version or the short bed?
8 foot is long bed.
Thanks!
Originally Posted by maxwoof
8 foot is long bed.
We have seen a couple of 9ft beds pop up also.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
