7 members (walter74, Sjm, Jman, baldeagle, SmalltownTRKGuy, moparguy, 1 invisible),
343
Mod | | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | To me all of the 1960-66 Chevy pickups look to be the same size.However some are listed as "1/2 ton" or "3/4 ton",etc..So my question is,is there any difference in size between the 1/2 and 3/4 ton trucks? Thanks! | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | "Size".. the answer is yes and no
"Yes" in regards to the size of suspension components. (6-lug vs. 8-lug wheels, larger springs, etc.)
"No" in regards to the overall size of the truck.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | There were no short wheel base (115") 3/4 ton trucks, so they do appear a bit beefier with the slightly larger tire/wheel diameter & 8 lug rims. The sheet metal is interchangeable between the C10 (1/2 ton-2wd), K10 (1/2 ton-4x4), C20 (3/4 ton-2wd), K20 (3/4 ton-4x4) & C30 (1 ton-2wd), so they do look, somewhat the same size, at first glance. | | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | The 3/4 and 1 ton trucks also have thicker frames. the one ton,s have a leaf spring,s with overloads on the rear. | | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | Excellent.Thanks for the replies!
One more question: One of the trucks Im thinking of buying has an 8 foot bed.Would this be the long bed version or the short bed? | | | | | Joined: Jan 2010 Posts: 45 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 45 | | | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | We have seen a couple of 9ft beds pop up also. | | |
