3 members (tclederman, UtahYork, 1 invisible), 105 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#823190 02/05/2012 3:48 PM
I am trying to find out more about epoxy primer. Does this primer create a barrier seal to prevent moiture from reaching the metal surface?
1950 Chevy 3100
In the DITY Gallery
77 International Scout ll
96 F-150 ext cab 4x4
2000 Tahoe
2011 chevy 3/4 ton 4x4
hardshell #823196 02/05/2012 3:56 PM
Yes, it does. What I do: sand blast metal, shoot with epoxy primer to protect until I can get to final bodywork. Scuff epoxy and apply plastic filler, high build prime with 2k urethane primer (cheaper than epoxy)
DavidF #823213 02/05/2012 4:47 PM
Thank you for your helpful information. I am going to get some pictures on here of the surface rust that I have left on the metal after much sandblasting. My only concern that I have now is how well the epoxy primer will adhere to these rusty surfaces.
1950 Chevy 3100
In the DITY Gallery
2000 Tahoe
hardshell #823962 02/08/2012 2:11 AM
My experience is to wire wheel after the metal gets exposed to air-moisture like yours did. I just hate to see all your hard work go to waste. Remember to clean your metal before the epoxy goes on.
real55 #823969 02/08/2012 3:01 AM
A wire wheel doesn't leave the 'bite' 80 grit does for the paint to adhere to. Wire wheel works good for removing stuff but sanding is still called for. Epoxy wants a minimum of 180 grit to bite into.
Give me ambiguity
or give me something else
CASO #831340 03/01/2012 9:07 PM
Epoxy Primer also has a window for top coating primers. Just make sure you follow the Manf spec's. I actually shot PPG epoxy primer on my underside of my burb then painted with a 2 stage. It came our really nice. For my topside I Epoxy/Body filled/Primed/Painted.
1948 3100
1948 Fleetline Areo
1951 Suburban Carryall ( http://photobucket.com/51Burb )
1957 3100
" Tell me who U Hang with & I'll Tell U who You are "!
Phoenician71 #831387 03/02/2012 12:25 AM
The "window" is if you dont want to have to sand between coats. If you exceed the "window", you need to scuff the paint to ensure the next material will adhere.
Many paint lines do not allow application over epoxy primer. This warning would apply to the "window" only and not be applicable if the epoxy is allowed to fully cure and then sanded/scuffed prior to applying top coat.
In other words, when applying subsequent material within the "window", you are relying on a chemical bond between layers. After the "window", you are relying on a mechanical bond between layers.
