| | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | I am trying to find out more about epoxy primer. Does this primer create a barrier seal to prevent moiture from reaching the metal surface? | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Yes, it does. What I do: sand blast metal, shoot with epoxy primer to protect until I can get to final bodywork. Scuff epoxy and apply plastic filler, high build prime with 2k urethane primer (cheaper than epoxy) | | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | Thank you for your helpful information. I am going to get some pictures on here of the surface rust that I have left on the metal after much sandblasting. My only concern that I have now is how well the epoxy primer will adhere to these rusty surfaces. | | | | | Joined: Nov 2011 Posts: 13 New Guy | | New Guy Joined: Nov 2011 Posts: 13 | My experience is to wire wheel after the metal gets exposed to air-moisture like yours did. I just hate to see all your hard work go to waste. Remember to clean your metal before the epoxy goes on. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | A wire wheel doesn't leave the 'bite' 80 grit does for the paint to adhere to. Wire wheel works good for removing stuff but sanding is still called for. Epoxy wants a minimum of 180 grit to bite into.
| | | | | Joined: Jan 2012 Posts: 29 Shop Shark | | Shop Shark Joined: Jan 2012 Posts: 29 | Epoxy Primer also has a window for top coating primers. Just make sure you follow the Manf spec's. I actually shot PPG epoxy primer on my underside of my burb then painted with a 2 stage. It came our really nice. For my topside I Epoxy/Body filled/Primed/Painted.
1948 3100 1948 Fleetline Areo 1951 Suburban Carryall ( http://photobucket.com/51Burb ) 1957 3100 " Tell me who U Hang with & I'll Tell U who You are "!
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | The "window" is if you dont want to have to sand between coats. If you exceed the "window", you need to scuff the paint to ensure the next material will adhere.
Many paint lines do not allow application over epoxy primer. This warning would apply to the "window" only and not be applicable if the epoxy is allowed to fully cure and then sanded/scuffed prior to applying top coat.
In other words, when applying subsequent material within the "window", you are relying on a chemical bond between layers. After the "window", you are relying on a mechanical bond between layers.
