3 members (Bill Hanlon, Otto Skorzeny, tclederman), 61 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#161987 10/02/2003 5:10 PM
I
I Offline
I am going to be building a 51 five window. I was wondering what kind of bench seat makes a good swap for the orginal? I am going to relocate the gas tank so I would like to place the seat a little futher back and maybe a little lower than the stocker because I am a big guy. Thanks!
#161988 10/09/2003 2:23 AM
This is a new forum, so please bear with us -- somebody should be along soon to give you a good answer. I, on the other hand, will give you a half-baked answer wink ...
In my '49, I have the seat all the way back and it's against the back of the cab as it is. A different seat may not give you any more room than what you get now (the gas tank is low enough that the top of the seat clears it.
Also, something to think about -- later bench seats have their own supports -- so if you take out the riser (involves cutting the truck which I am not personally in favor of), you can put just about anything that fits width-wise.
Hope this info helps.
Regards,
~ One of many.
#161989 10/14/2003 12:24 AM
I
I Offline
I didn't realize you had to cut anything to change the seat. I am not in favor of this either but it has already been done on my truck. It has two old bucket seats in there so I guess the damage has been done. Thanks!
#161990 10/14/2003 1:03 AM
If you can find an original seat and have it reupholstered with a shallower back, you will fit in there fine. I am 6'2 and have size 15 feet and I am just fine in my cab with original seat.
Paint & Body Shop moderator
4ontheFloor #823036 02/05/2012 2:07 AM
Hey, rather than starting a new thread I'll bump this one up.
I'm a big guy too with a big ol'gut and I'm looking for anything that will give me some more breathing room. Any seat suggestions or tips and tricks that you've discovered?
Dallas Huybregts
Sherwood Park, Alberta
1951 Chevrolet 1300
email
Photobucket
flickr
Dallylamma #823236 02/05/2012 5:48 PM
The answer is to find a replacement seat with a back that is as thin as possible and then raise the seat up as much as you can and still be able to see out of your rear view mirror. A lot of guys seem to think that moving the gas tank from the cab will give them more cab space for seating but that results only in an increase in storage space behind the seat. Unless you have a very low seat back (uncomfortable) the seat meets the back of the cab above the gas tank recess. If doing a resto-mod you will also gain some room by using a smaller diameter steering wheel.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
56picup #823274 02/05/2012 8:15 PM
Y
Y Offline
Another option, is to shorten the steering column, or install a tilt column. Do a search, it's been done by other bolters.
Yakimabowtie #823834 02/07/2012 3:47 PM
I'm 5'10" and the original seat is just fine. I plan to recover it. Vinyl is hot in the summer
Dennis
oldbluetruck #833200 03/08/2012 12:54 AM
I used a seat from a 1990 full size Chevy pickup. I had to do a little modifying, but it was worth it. I got a lot more leg room and head room and it's a lot more comfortable than an original seat.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
pablos49 #851704 05/15/2012 5:18 PM
The full size pickup seats fit good in the 1950 and up trucks. For anyone happening upon this thread, I thought I would add that the full size pickup seats are much too wide for the earlier cabs, but the S10 seats fit good in those.
My 46 GMC on Photobucket
46gmcpu #852394 05/18/2012 7:26 PM
I bought new seats from discountvantruck.com
The low back buckets give you the most legroom in a vintage truck and you can get a console with storage and pick your upholtery. After looking at junkyards for seats I decided that by the time I recovered and modified a seat from something else, it was probably better to go new.
Baba #852533 05/19/2012 6:46 AM
Baba,
That'e the route I'm taking as well for the '56 pickup I'm building for the wife. I like their "American" 40-20-40 Low back with the center console. I'll have mine done in cloth, leather is to hot for me...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Moderated by  ndkid275, Phak1
