1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Can someone tell me if a bellhousing Part#gm7-3815891 will fit in a 1959 1/2ton truck?
Thanks, Tommy
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tommy, I can't find that number in my parts books, however casting numbers are more often than not part numbers. Also you didn't say if this bellhousing is for a six cylinder or a V8. Could you post a picture? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | It's a v8 bell housing. Suposed to be 60-67, some of the mounting ears are angled and some are straight.Was just wondering if it would work on a 59. I don't have a pic.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Check here Your casting number is mentioned. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tommy, the early 60s trucks had hydraulic clutches, and the throwout arm was on the right side of the bellhousing. The later 60s went back to the throwout arm on the left side. The bellhousing should have angled mounts, throwout arm slot on the left side, and a single bolt hole (threaded) in the angled mounting pad, hope that helps. | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | This bellhousing will fit a '59 truck. 3815891 bellhousing Another one. Cleaned up 3815891. The album contains a photo of a 392505 which has the larger center hole for new transmission options but is otherwise the same. 3815891 bellhousing
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | thanks all I was thinking of trying late 6cly and wondered about the mount.
