5 members (Hotrod Lincoln, Gdads51, Gray_Ghost, David Bush, Gib70), 118 guests, and 0 robots.
Topics128,051
Posts1,055,735
#822815 02/04/2012 1:25 PM
Can someone tell me if a bellhousing Part#gm7-3815891 will fit in a 1959 1/2ton truck?
Tommy
Tommy
59 apache 1/2t
261 short stepside
Tommy #822880 02/04/2012 5:17 PM
3B Offline
Hy Tommy, I can't find that number in my parts books, however casting numbers are more often than not part numbers. Also you didn't say if this bellhousing is for a six cylinder or a V8. Could you post a picture?
3B #822883 02/04/2012 5:25 PM
It's a v8 bell housing. Suposed to be 60-67, some of the mounting ears are angled and some are straight.Was just wondering if it would work on a 59. I don't have a pic.
Tommy
59 apache 1/2t
261 short stepside
Tommy #822890 02/04/2012 5:55 PM
Check here
Your casting number is mentioned.
Steve
'49 3800
'52 3600
'57 3100
Tommy #822895 02/04/2012 5:58 PM
3B Offline
Hy Tommy, the early 60s trucks had hydraulic clutches, and the throwout arm was on the right side of the bellhousing. The later 60s went back to the throwout arm on the left side. The bellhousing should have angled mounts, throwout arm slot on the left side, and a single bolt hole (threaded) in the angled mounting pad, hope that helps.
3B #822897 02/04/2012 6:03 PM
This bellhousing will fit a '59 truck.
3815891 bellhousing
Another one.
Cleaned up 3815891.
The album contains a photo of a 392505 which has the larger center hole for new transmission options but is otherwise the same. 3815891 bellhousing
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
OlBlue #822940 02/04/2012 8:19 PM
thanks all I was thinking of trying late 6cly and wondered about the mount.
Tommy
59 apache 1/2t
261 short stepside
