1 members (GMCJammer51), 153 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#822679 02/04/2012 12:56 AM
I am putting turn signals on my 1948 chev panel van. I have run my 4 wires to the back. One goes for the brakes, two wires for turn signals-one for each side. And one for the lights. All is well till I turn on the lights which kills the turn signal. If I change the wires then the turn signal kills the brake lights. What am I missing. I put the turn signal wire to the tale light and not the brake light because I won't be out that much at night but know I must be doing something wrong. Thanks for any input.
first48 #822696 02/04/2012 1:33 AM
I just received my column mount turn signal. I can send you the wiring diagram. Give me an email address. You did not mention the flasher?
GWWirth #822751 02/04/2012 4:30 AM
Riding in the Passing Lane
Your light is not grounded or the bed is not grounded to the frame.
1972 Chevy c10 Cheyenne Super
GWWirth #822752 02/04/2012 4:31 AM
You also didn't mention what kind of switch you have. By you saying you have 4 wires going to the back I'm assuming that you have a 4 wire switch. You can not wire those signal wires into your existing system. You need separate dedicated turn light housings.
Cletis #822819 02/04/2012 1:39 PM
I was wondering the same thing. Is it a 4-wire directional switch? If so, one wire will power the blinkers on the left side (front and rear), another will power the blinkers on the right. The remaining two wires will go to the flasher.
1956 Chevy 3200
