3 members (GIJOE298, Peggy M, 1 invisible), 123 guests, and 2 robots.
Topics128,078
Posts1,056,056
Members48,433
Been wanting to add the Custom cab moulding to my '64 C10. They sell for big bucks (about $200) for a shiny pair online and the ads usually refer to some kind of mounting hardware.
I'm checking them out on ebay and from what I can see, the mouldings come with some screw holes and that's about it. This is my first project car and I'm going for more of a hot rod thing than a full perfect restore, so a little patina and wear doesn't bother me.
Can I easily affix the cab moulding using just screws or is there something additional I need? I've checked a bunch of online catalogs and didn't see anyone selling just the mounting hardware ... makes me think that's because it would just be 8 simple screws! Any tips?
'64 C10 1/2 ton fleetside
There's a clip that screws to the cab and the moulding hooks to it at upper rear edge so it's hidden under the moulding. Then you have the mounting screws in the door jam and one at the rear of the cab where the moulding wraps around. On my '65 I didn't have the clip so I used several layers of 2 sided outdoor mounting tape in that corner and it worked.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Thanks John ... makes sense and seems to be an inexpensive solution (particularly as I'm looking at really needing a new radiator - $375!)
The clips were pretty much just a thin steel strip that the trim slipped in behind. You can easily build one out of some 1/2 inch wide strap.
I can send you a picture of what they look like if you want.
That would be great! I'll update my profile to include my email address or you can post them in this thread in case someone down the road has the same question.
Can I easily affix the cab moulding using just screws...... Any tips?
Yes you can fellow Hot Rodder, only screws are needed, no clips required. thumbs_up
Here is a "How To" thread I posted after I installed Custom Cab trim panels on my 65:
http://www.chevytalk.org/fusionbb/showtopic.php?tid/270929/post/2149858/hl//fromsearch/1/#2149858
Hope that helps!.
Thanks John ... good link. I'll be using that when the sails I bought come. Good thing too, because a few of the screw holes are a little bigger than they are supposed to be, which means I can use screws with the right size head for the job.
Given that the sails are otherwise in good shape, the 45 bucks I paid, including shipping, ain't a bad deal.
Sweet.... I paid about $47 for mine about 4 years ago, so you done good! thumbs_up
Plus we are buying vintage Americana... a.k.a. OEM parts vs. aftermarket Chiawanese versions made from old Bud Light cans.
I know that Brothers or the Car& truck shop in southern Calif Carries the clips to mount them. The LMC Trucks carries the clips too.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
John Nice tip on the screws! I had seena trick like that that once before, but rather than countersunk screws pan head screws were used and the trim was notched slightly for a more positive fit. The screws were just loose enough for the trim to slip under and not be loose.
Brian I can still send you a picture of the clips if you would like.
That'd be great, pope ... I'm down for all the info I can get to do the job.
I first tried pan head screws but I felt they may loosen over time. I changed to counter sunk screws so I could tighten them down such that they won't back off later on down the road.
Lots of ways to skin this cat. thumbs_up
Brian I just sent a picture to your e-mail. let me know if you would like others
