| | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | I am putting turn signals on my 1948 chev panel van. I have run my 4 wires to the back. One goes for the brakes, two wires for turn signals-one for each side. And one for the lights. All is well till I turn on the lights which kills the turn signal. If I change the wires then the turn signal kills the brake lights. What am I missing. I put the turn signal wire to the tale light and not the brake light because I won't be out that much at night but know I must be doing something wrong. Thanks for any input.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I just received my column mount turn signal. I can send you the wiring diagram. Give me an email address. You did not mention the flasher? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Your light is not grounded or the bed is not grounded to the frame. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You also didn't mention what kind of switch you have. By you saying you have 4 wires going to the back I'm assuming that you have a 4 wire switch. You can not wire those signal wires into your existing system. You need separate dedicated turn light housings. | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | I was wondering the same thing. Is it a 4-wire directional switch? If so, one wire will power the blinkers on the left side (front and rear), another will power the blinkers on the right. The remaining two wires will go to the flasher.
1956 Chevy 3200
