| | | Forums66 Topics128,022 Posts1,055,269 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Finally a day off with some warm weather. Spent about four hours in the blast cabinet working on the drivers side rear spring stack off the '54 1 ton stake. Making progress but it's slow as usual.
Bruce | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | got about a third to half of rear cross boxed. waiting for bolts so i can finish the rest of it. mo
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | got my '52 VIN verified, weighed, and registered. she's on the road! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Yesterday I installed my grease zerks and cotter pins, and installed my AC pressure switch, set the timing and put a bright yellow dot on the timing mark. Tomorrow I'll attack the hood. Then it'll be off to Rich's for my exhaust. Rich's
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Didn't get too much done but took it out for a rumble and rattle ,still lots to do! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You inspire me John. I will add some recent pics when I get the hood on. I think I'll do a video when I'm finished. I noticed you haven't added backup lights. Will you be doing that. Also, what are your plans for your bed.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks Jim, I haven't bothered with back up lights,it never had them when it was original,and it's something I can live without. It's not a legal requirement here either. You may have noticed my 3rd brake light wasn't wired either. Although as you can see in the video,the LED lights are pretty bright!
The bed will be done as Chevy intended,although probably with oak rather than pine,as soon as I've saved some more cash! I'll have the timber sourced locally and machined for bed strips etc.
| | | | | Joined: Jun 2011 Posts: 290 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 290 | I ran a sand blaster for about 7 hours today. Now the entire bed of my 50 chevy 3100 has been stripped to the metal (and small rusty impressions). Going to treat the rust next and then apply epoxy primer. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Well, maybe not today, but yesterday I replaced the push rod pan gasket. So far, so good. Other then that, not too much. I should be doing more engine detailing, painting, etc.. but ...
| | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | I thought my truck ran well before, but I put in new wires, plugs, cap, rotor, points and condenser and wow!!! Pretty dramatic difference. Didn't realize it but it must have been dragging a cylinder because it is so much smoother with a noticeable increase in power. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Found out that I am in fact getting spark at the plugs! ...now to figure out why she still won't fire up.  | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I put trim rings on my Suburban wheels. Before After | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | What went wrong with my day . . . or . . . POR15 Storage advice. Read on: casey, as mentioned above, I drilled a 1/4" hole in the center of the lid and poured out small amounts each time, wiped it clean and put a new piece of duct tape over it each time. Its been hot as a firecracker here and I"ve used some out the can every few days and its still good. I had the hookey puck thing happen to me to.....then another bolter, I forgot his name,mentioned drilling a hole in the lid and it works for me. Anwyone else tried this?.... am I just lucky this go round? The secret to keeping POR15 fresh is to get the can resealed. I found that using a sheet of kitchen food wrap, the clinging kind seemd to work pretty good if used under the lid. It sealed and allowed me to get the lid off w/o tearing it up. But maybe the small hole idea is even better. The subject of "storage of POR 15" has been well covered above. I just thought I'd add my own funny story to the list. I recently stored some POR15 in a 16oz Lipton Tea plastic bottle. I filled it to about 1" from the top and closed it up tight. I have recommended this to others because I saw it somewhere and it sounded like a great idea. Simple, right? Just pour out what you want, then squeeze the botttle a bit to get rid of the extra air and reseal. BAD IDEA!!! It may have worked for others, but not for me. Here's what happened to me tonight. 1. I had to cut the lid off with a utility knife. 2. The POR15 came bubbling out like a volcanic eruption. 3. I now have a few freckles that were not there this morning, and they are semi-glass black. 4. I have a black line on my nose that will be there for weeks and make for interesting conversation. 5. The POR15 was lumpy, but did spread out OK and will probably cure just fine. 6. The sweatshirt my wife wanted me to throw away has POR15 all over the sleeve. It's a shame, that sweatshirt has been with me for over 15 years. 7. I painted stuff with POR15 that I had no intention of painting, but it was either that or waste the stuff that spilled. Waste POR15? Shoot no! That stuff is expensive! 8. I can still laugh about it!
| | | | | Joined: Jan 2011 Posts: 23 New Guy | | New Guy Joined: Jan 2011 Posts: 23 | Over the last few days, got started on the rebuild of the front end, and the upgrade to my brake system. Fun work so far, and nothing's broken where it shouldn't yet. Figure that'll change before I'm finished, but it's off to a good start.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | That looks great Cletis. Is that on the suburban? What wheels are those?
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes that's the Suburban. The wheels are stock centers with new Stockton rims installed. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks, I just checked their website. I've been looking for wheels. Back when I needed wheels for mockup I bought what I thought would fit my center cap, Camaro rally wheels. However the caps would not fit the wheels.
~Jim
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | That company had a poor reputation in the past. Don't know if it has improved
I got burned by them
Good luck
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks for the warning. They may have improved in whatever area needed improving as Cletis must have had a positive experience with them.
~Jim
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | got the frame straightened out today. the one front horn was off about 3/8 inch. pretty easy for me, i dropped it off at the bodyshop, went home and cleaned the shop, since it was gone. now i can start some major frame work.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Yesterday, after attempting to charge the air conditioner and finding a halfway crimped hose spewing freon, I got it working and blowing colddddd air. Success!!! Big plans for today... Today was designated Hood day. I had planned on getting the hood back on after 6 years. That is all I lack besides exhaust, carpet and headliner. Then I realized the air conditioner evaporator was too close to the kick panel to loosen and tighten the hinge bolts. Lesson learned: put your hood on before installing your evaporator. After loosing the evaporator and getting the bolts loose and ready to set the hood I discovered I had no shoulder bolts for the hinges. I had ordered a full set of stainless bolts for the AD truck which included these. After digging around I found the original bolts which, though not stainless are in perfect shape. Tomorrow I'll use these and hopefully get that hood back on. "The best laid schemes o' Mice an' Men..."
~Jim
| | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | had the cab sandblasted and primered the frame rails. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Nov 2011 Posts: 12 New Guy | | New Guy Joined: Nov 2011 Posts: 12 | Replaced the battery tray on my 65 C10. I had to grind off the small bolt that screws into the fender to remove the old tray. I also found 4 original 6 lug wheels. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Yesterday, after attempting to charge the air conditioner and finding a halfway crimped hose spewing freon, I got it working and blowing colddddd air. Success!!! Big plans for today... Jim, How come you didn't find the leak when you evacuated the syetem?
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | ...don't know. I guess the leak wasn't bad enough to hear the sucking sound. Also the leak might not have leaked during evacuation.
~Jim
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | It was just like christmas in february for me. Box of new parts arrived today. So today I went out and checked to make sure they were right. Most were fine but the 2 rad hoses were wrong and i'm looking into the fuel pump. The pump they sent is half the size of the one on there but I think it is because the old has the vacuum on it to work the wiper motor.
Rick 58 3600 4 on the floor
| | | | | Joined: Jun 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2011 Posts: 59 | | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Nice, real nice!  | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | scored a set of 15" 6 lug brand new ralleys for 250 with bowtie center caps, chrome, and just the right back spacing to clear my cpp front disk brake kit! ....i love craigslist! | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Just finished my winter must do list. I started 3 weeks ago and removed my 3spd trans and sent it to a long time trans shop in Vancouver(Berts Transmission) to have them stop it from jumping out of third.(Note: I had all ready installed new synchro rings and that had not worked.)They found 4 problems, 3 from PO and the main one was the maindrive shaft( input shaft) being worn out. They replaced it with a rebuilt one.( 1 week turnaround) Next was the poor threads on the diff for the cover. I had to install 4 Heli-coils. I also changed the engine oil and filter, greased all the frame grease points.Next I want to install my Fulton visor.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | I got my starter from napa yesterday. Put It on this evening. Got me a water bottle and some fuel line.. Filled the carb full and she fired right up..Im excited. Not too bad for my first 216 rebuild.. Just wish i had the cab on it so i could go for a spin. That'll give me some motivation to get the cab done..
Daniel
1953 Chevrolet 3800 Stepside
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | started the reinstall of the mustang ii suspension crossmember today. (took it out to straighten a frame horn and i had it off maybe a 1/16th on ten feet from front to back). got the new box plate cut and tacked in. also bead blasted a bunch of small parts now that i have air again. tomorrow weld the plate solid and cut in the reliefs for the rack and pinion. taken it easy this week kind of tired. lol MO
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Where's your pics MO? Let's see some of those welds.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | For the last few days I have had the truck over at a friend of mind's place. He has a lift and we have been working on the running-board arms. I would imagine very few of these old trucks have escaped a side bump or "beer bruise" to the running boards. I never considered this until now that my boards are on and the splash panel doesn't line up equal to the other side and generally nothing fits well. I have shimmed three and put a pry pipe on one to drop it about an inch. My advice to anyone with their cab off would be to check the level on these arms to make sure they are level and true.
~Jim
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | no pics, my welds are ugly and i have no camera right now. also dont have any clue on how to post pics here.
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | welded the boxing plate solid. also started the measuring and marking process for the mustang ii crossmember. cleaned up the crossmember and started to cut for the rack and pinion reliefs in the frame. i was just starting to test fit the first relief(half of a metal tube) when the wife came and shut me down for supper. didn't work to hard this weekend but i am moving on anyway. see you all next weekend. mo
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Buying a camera at Walmart is easy. Samsung You'll find pictures of your work most helpful when parts are ready to go back together. Posting here is also easy once you get the hang of it. Just take one step at a time and get the camera first.
~Jim
| | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | New water pump. thermostat. tomorrow maybe get headlight dimmer switch installed.  | | |
