| | | Forums66 Topics128,042 Posts1,055,595 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 39 New Guy | | New Guy Joined: Sep 2011 Posts: 39 | I am trying to figure out what type of heater I have in my '51. I see threads and pictures on air flow and recirculating heaters, but my heater does not look like any of these. It is shaped like a cube/box with the heater core laying flat at the top of the unit. The fan blows air from the base of the unit.
I took it apart to clean and paint it up. I will post pictures once I complete the rebuild. I thought I would post the description to see if anyone recognizes my description. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | After market, there were a ton of them sold buy auto parts stores and places like Sears Roebuck & Co., Wards, Western Auto, Warshawsky's and on and on. You need to post a photo and then maybe, just maybe someone might recongnize what brand it is.
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2011 Posts: 39 New Guy | | New Guy Joined: Sep 2011 Posts: 39 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | looks like generic aftermarket "one size fits all", JC Whitney or a number of others  Bill | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | What you have is an aftermarket Arvin brand heater. You are missing the white arvin script on the front. That is what the oddly spaced holes in the front are for, that is to mount the script. I have/had one in my 52. I disassembled, sand blasted, primed, and painted it, also while it was disassembled I had the core cleaned and pressure tested. I then found another heater that had a good script, but no motor. I hadn't started on the new case, when I got a super deal on a working deluxe fresh air heater. The fresh air heater is currently waiting on cleaning and paint as well a pressure test on the core. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Git_Er_Dun I suggest you grab that arvin script. I looked high and low for one like that, and after a year gave up. That is how I wound up with a second case. So I could cast a new script for my heater. It is a good deal I think, it beats buying a case (if you can find one)the casting resin ect. I figure that the script I made cost about $75. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My '52 had an Arvin heater that I immediately ripped out to replace with a GM fresh air heater. I think I still have the Arvin and I know it still had the logo. Not sure of the condition, but you are welcome to it. Send me a PM, with your info, if you want it.
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | DavidF, If Git_Er_Dun didn't take that Arvin heater you might consider selling it on Ebay. The last one I saw that had been cleaned and painted went for over $80. If you don't want to fool with it, I will take it and pay for the shipping. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Too late. I cut out a section of the sheet metal box with the Arvin logo and sent it out to Rick. Too much work to restore the rusty old box for only $80 value. But, if you want the heater core and/or fan, let me know and I will grab those parts before throwing the whole lot out.
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hi, If it is in that bad of shape Send it to the scrap yard. I do appreciate the offer for the rest of the parts. Jim. | | | | | Joined: May 2011 Posts: 33 New Guy | | New Guy Joined: May 2011 Posts: 33 | i have a 49 ,3800 where CAN i find info on the heater regards r.j. | | |
