1 members (PullG),
40
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82243 08/29/2007 9:24 PM | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | I have recently put a 1989 350 TBI motor in my truck. I have attached all the whistles and dimes, but when I go to turn it on; the injectors aren't getting any signal to spray fuel.
I have a new pump and it works well, so its not a fuel problem.
All the sensors I could think have been checked, I just can't seem to figure it out.
I need your help! | | |
#82244 08/29/2007 11:01 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Make shure the ignition system is working. It seems to me the fuel system is set up so if there is no spark the injection system won,t work. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#82245 08/29/2007 11:24 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Its been a few yrs, but seems I had one w/a bad module in the dizzy that gave no fuel but a very weak spark-the injectors got their signal from the distributor. New module & bam, fired right up. | | |
#82246 08/30/2007 12:19 AM | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | could it be anything else, my ignition module tests out just fine | | |
#82247 08/30/2007 4:18 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Do you still have the ALDL & check engine light? try flashing the dash light for codes if so. Are you sure evrything is plugged in good? Sometimes after unplugging & yanking around while removing/installing an engine etc., those small metal terminal ends on Weatherpak connectors get bent, then when plugged in that terminal won't make a connection on one or two wires. | | |
#82248 08/30/2007 10:32 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | | | |
#82249 08/31/2007 3:25 AM | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | TPS is good.
Any other ideas? | | |
#82250 08/31/2007 4:02 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by N. Phillips: TPS is good.
Any other ideas? no ALDL? no codes? | | |
#82251 08/31/2007 5:48 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | The only other thing I can possibly think of in your case is a clogged fuel return line. But that's a bad guess because I think the injectors would still blow the air out and still open up and deliver fuel, even if the clogged line would cause a big surge in rpm every time the throttle was cracked. | | |
#82252 08/31/2007 6:45 PM | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | There should be a constant 12 volts to each injector plug with the ignition turned on. The second wire to the injector is the ground, provided by the computer through the quad driver circuits. Check the injector plugs with a test light (one of the few places that tool is appropriate!) to see if the circuit can flow enough current to light up the bulb, then check for continuity all the way from the injector plug to the computer on the ground side. By momentarily grounding the return wire, the injector shouls squirt. Don't leave the wire grounded for longer than just a quick tap, as the injector windings won't stand a continuous circuit without burning out. If all that checks out OK, try swapping a known good computer into the circuit. Jerry
#82253 09/04/2007 12:57 AM | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Oil pressure sending unit will keep injectors from working. | | |
#82254 09/04/2007 1:38 AM | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Ditto on the oil pressure sending unit. GM failsafe if there is no oil pressure at the switch, engine wont run, fuel pump wont pump. There should be a 3-wire switch. One wire for the idiot lamp, the other two tell the ECM there is oil pressure
Scott
#82255 09/04/2007 2:44 AM | Joined: Aug 2007 Posts: 42 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 42 | be slightly careful with assuming the oil pressure sender switch is bad. i had an 87 that had one go out but it was set up to give the engine fuel for something like 10sec then shut down when it didnt read oil pressure. if your not getting and fuel even on start up it may not be the oil pressure sender (just my $.02) from what i have seen of these type issues at work i think jerry (hotrod) is on the right track | | |
#82256 09/04/2007 12:36 PM | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | There's a 2-second fuel pump run programmed in when the ignition switch is turned on, plus a constant-run pump mode while the starter is cranking. The oil pressure switch is rollover protection to shut the pump off if the car loses oil pressure. If the engine starts, runs a few seconds, then quits, then check out the oil pressure switch. Jerry
