| | | Forums66 Topics128,120 Posts1,056,321 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82240 08/29/2007 5:03 PM | Joined: Jan 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 24 | In my quest for the t-5 swap, I started to purchase the parts need to complete the job. trans, pressure plate, clutch disc, throw out bearing and thrust bearing. Did many searches and PM's to others here and gathered my info and parts and headed out to the garage.
Just for the fun of it I compared the two clutch disks, the RCF-4201 and the one that was behind my engine. looked identical except for the splines, I thought. Wrong. it turns out that the new disc has a larger diameter than the old one by about a 1/2 inch. 1/4 per side. It matched up nicely to the reman PP that I got a great deal on, but wait.
now comparing the reman PP to the old... it too is larger. bolt holes are too far apart to bolt up to the fly wheel. It seems that some were along the line there was a change. 54 -62 have the same PP and clutch disc. While the 47-53 have the smaller PP and disc. So I guess my question is will the fly wheels interchange with out messing up the balance of the motor. And would it be easier to just change the new disc to a Vega and try to locate the correct PP,which is very hard to find a good deal on by the way. Or keep the larger pp and disc and change the fly wheel. If I change the fly wheel will I have to change the starter too? Just trying to get things together with out too much swapping of parts. | | |
#82241 08/30/2007 12:08 AM | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | If you have room on the original flywheel & in the clutch housing to accomodate the larger pressure plate, you can have the flywheel re-drilled to accept it. Most automotive machine shops can do that for you. Doug | | |
#82242 08/30/2007 12:38 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You will have to change the starter too, unless you have the later flywheel machined to accept the earlier ring gear.
