4 members (MRMEROTH11, Hotrod Lincoln, 52Carl, klhansen), 70 guests, and 2 robots.
Topics128,052
Posts1,055,773
#819618 01/25/2012 3:36 PM
does anyone know if the bolt on type front end cross member will work on a 1953 3600 series pickup. they all say halfton but i was wondering if this wouldwork on the 3/4 ton. also how about the rear end kits . thank you . i want to do both and then put in a small block with a 700r4 trans. this would also make it easyto put in a 9 in. rear. i think.
I'm going to say yes. The 3100 and 3600 are virtually the same from the cab on forward. They have the same springs and spring mounts. The difference is when you get to the front axle. The 3600 has larger spindles and king pins. Also, the 3600 will have larger brake lines. So a front end kit for a 1/2 ton and 3/4 should be the same.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
A 1/2 ton IFS from 63-87 will work on your 3600. I used a narrowed front end from a '79 on mine.
Robert C.
I'm a Genius in the making.
1950 3600
wonder if the 63-87 narrowed would work on my 37 without looking too truck like since i know the front axle of a 51 fits ok
1937 1/2 ton
Daniel, I don't think anything could look more "truck-like" than our leaf spring/bar axle setups.
regards,
Leon
