| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | Hey so this is a simple question im sure, but i cant seem to figure it out. How do you remove the lock mechanism (just bought a new one) from the glove box door in a 1954 3600 chevy?
I also dont have the key to the original glove box lock but it is in the open position. I can push the lock button in.
Thanks | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | One screw on the inside , remove the retainer bracket, then it pulls out from the front...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | Hey thanks for the quick reply!
Unfortunately, the lock on my glove box is different then yours. Guess i should have posted a pic first.
I just uploaded some pictures of it onto my truck website. Just click on the link in my signature and it should take you right to them. If it doesnt let me know and ill try something else.
It does look like it should pull out from the front tho.
thanks | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Looks like the screw is missing... It might be just rusted and stuck... Try something like WD-40 on it, wiggle it around and see if it will push out from the back...
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Agreed, it looks like the bracket is missing. It should just come out the front. Maybe someone in the past used an adhesive to glue it in place since they were missing the bracket?????
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Chooglin - This is the diagram for the glove box lock from the '29-'54 Master Parts Catelog. The diagram near the bottom of the first column on this page from the Truck Shop Catelog shows a "RETAINER" that is similar to the one on your lock. I don't see that retainer on the MPC diagram and I don't see it on my '54 glove box lock ... unless it is behind the front chrome escushion and hidden inside my glove box door. It's been a while since I had the lock out. That "RETAINER" may be jammed into your lock opening and holding the lock in place. When you finally get the lock out, you will need a '54-'59 Glove Box Lock Retainer (#54-04507 on the Truck Shop catelog page), and a '54-'59 Glove Box Door Lock Gasket (#54-04505). They are available from most suppliers. You will also need a 6-32 screw and lock washer to hold the retainer to the lock. Doublecheck the screw size. Don't overtighten the screw. The lock is potmetal and will break or strip. If the spring on the door hinge is not broken, remove the door and play with the spring on the hinge so that the door will pop open by the spring loaded hinge when unlatched. You should feel spring resistance when closing the door. >> Point of interest - did you notice the round key in the MPC diagram? I thought all keys in '54 were hexagonal.
Last edited by LonnieC; 02/03/2012 3:47 PM. Reason: clarified the hinge spring operation
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey thanks for the quick reply!
Unfortunately, the lock on my glove box is different then yours. It does look like it should pull out from the front tho.
thanks I have two glove box doors which have the same retainer as the one he pictures with the funky clip.
Bruce | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | How do they release Bruce?
| | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | Just got back out to the shop. With a little more elbow grease the lock assembly popped right out the front.
Looks like Tiny and Lonnie were right. The bracket that may have been there originally was just missing. You can see where the screw in the back would thread into it. Wonder why that would dissapear?
Thanks for the great advice and the links to those couple of parts too, much appreciated.
My '54 lock does not have the retainer that is pictured on your lock. I removed the lock from my glovebox door today just to make sure that the retainer is not hidden between the front and rear sheet metal of the door. Your retainer in the Truck Shop Diagram, and Bruce said that he as a couple of locks with the same retainer.
How did you remove the retainer on your lock? What secures it to the lock?
And yes, it looks like your lock is set up to use a retainer like Truck Shop #54-04507.
Thanks for the update.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | How do they release Bruce? I don't know yet. I haven't gotten to the point of messing with it. I got interested in this thread because I couldn't figure how it came out either.
Bruce | | |
