6 members (Uncles51, spanky, texas46, Hotrod Lincoln, Southerntruck, Steelonsteel), 69 guests, and 1 robot.
Topics128,022
Posts1,055,382
Members48,422
#822263 02/02/2012 6:31 PM
Can I run 15/8 rally wheels from 70-80's Chevy 4x4 on my stock `58 Chevy 1/2 ton?
1959 Shortbed stepside 1/2 ton project
[Linked Image from i236.photobucket.com]
olddaze #822403 02/03/2012 2:17 AM
Yes. I have a set on my '55 1/2 ton. Depending on what year truck they came from, you may need to do some minor grinding in the center bore to allow them to fit. Later versions have 6 "tabs" in the bore that were for centering the wheel on the hub. Those will interfere with the hub on the older truck as it is slightly larger. You only need to take the tabs down to match the bore diameter. Also, you may want to remove the rivits on the front drums. They were an issue with mine.
Bill Burmeister
LONGBOX55 #822469 02/03/2012 5:53 AM
Thanks that's just what I needed to know!I checked out the link to the pics of your truck. Nice truck, what size tires ya running?
olddaze #823030 02/05/2012 1:53 AM
30 x 9.50 x 15. Fills the wheelwells very nicely, but still plenty of clearance.
Bill Burmeister
