The temperature gauge is one that has lights, no pointer. When you first start up, the gauge will have a green light indicating cold, when it reaches temperature, no lights, and if it is too hot, it will light up red indicating hot. Problem is the hot light comes on when the cold light comes on and when the cold light goes out the hot light stays on. There are two wires that go to the temperature sensor that screws into the head. Questions: 1. Does anyone have a wiring diagram, or can explain to me how this works. I am used to one-wire going to the temperature sensor, not two. 2. Even if I pull both wires off of the sensor, the hot light will still stay on. How come ? Thanks in advance.
